Transmission problem!
Hey all hope you can help.So tonight I changed my filter and seal,put in new atf-4 and started up..When i put it in gear and tried to move. it was slow to engage and take off.Then I thought I overfilled a bit and took a litre out to only not be able to move in any gear!!!
I have a similar issue with my D except the transmission will not engage in any gear. Just changed fluid and both filters. Also, receiving the following codes:P0121, P1784, P0732, P1734, P0731. Did taking fluid out fix the problem?
2000 Dodge Durango 4.7L 4x4
Trending Topics
Fixed the problem!Wasn't getting any fluid pressure in system(could switch gear without brake on),so pulled the dreaded pan(on my back 30 deg),so find out that the seal on the stem are a little different.I swapped the old onto the new and stuck back in(make sure you hear in "snap" into place.Bolt back up and fill wil 4.7l .Hope this helps!
Sucking air will do that.....LOL
BTW<---- a 4.7L has a 45RFE transmission and there is 2 filters on that transmission. A flat one and a screw on type.
P0121 TPS Voltage Does Not Agree with MAP
P0732 Gear 2 Incorrect Ratio
P0731 Gear 1 Incorrect Ratio
As for the P1784 and P1734 I have no clue so I don't want to send you in the wrong direction. Please PM master tech
