High Pitched Squeal
Put on your thinking caps. 2003 Durango 4X2 and 4.7 liter V8. At less than 45 MPH we get a high pitched squeal (not very loud) and it goes away if you put a little pressure on the accelerator pedal (release pressure and the squeal is back). Not lights or codes and it has been with us for several months. Any suggestions gladly accepted. Yes it has been in the shop and all I get back is dunno.
id look at components that are loaded when you accelerate or provide engine power to keep the vehicle moving, wheel bearings, pinion bearing, ujoints, its really hard to diagnose sounds without having any idea where its coming from (sometimes its hard to figure out even when you are in the vehicle i know)
+1 indy.. i would go ahead and put a new tensioner and serpentine belt on there... if that doesn't fix it then try the idler as well... my tensioner was all buggered up when i got the car so replaced it and the serpentine belt... just replaced thebelt again after my waterpump had a catastrophic failure and tore it up...
If you do replace the belt, spend the extra $15 for the premium belt. Cheaper belts tend to squeal more.
Trending Topics
Thanks for all the replies. Ball Joints are new and tensioner and belt (DAYCO) changed last year (haven't done idler). Yes it sometime squeals in idle (P) but is short lived so I never get to catch it at idle (guess I need a driver and under hood observer). The noise is similar to an electrical nose but yet not quite. I will keep up the Quest and if I find it before it finds me I will let you know.
Might sound funny but, next time its sqeeking try and turn on the a/c and see if it lessens or goes away... had a sqeek on my last truck that i could not find and one day i noticed that when i turned the a/c on it stoped, turned out to be an a/c compressor bearing.. like i said i know its sounds wired but, what you got to loose?
