02 Durango p0141 p0161
Old Aug 14, 2011 | 02:09 PM
johnnycraig's Avatar
johnnycraig
Default 02 Durango p0141 p0161
I have a 2002 durango with the 4.7, 2 wheel drive. Recently I had the codes p0141 and p0161 both come at the same time. I figured it was a fluke because both 02 sensors couldnt go out at the same time so I reset the codes and they came back the next day. I have traced the wires and they look to be in good condition. My durango has 4 sensors total. It doesn't seem possible that two sensors go out at the same time, has anyone else encountered this?
Old Aug 14, 2011 | 04:59 PM
hydrashocker's Avatar
hydrashocker
P0141 1/2 02 Sens Relay
P0161 2/2 02 Sens Heater Failure
Ensure there is no brake fluid in any of the harnesses. Have you been driving in wet weather lately?
Old Aug 14, 2011 | 07:02 PM
johnnycraig
The harnesses are dry on the sensors themselves and also where the sensor wires connect to the larger harness. i have searched a bit online and found that there are issues sometimes with the heater relay causing this problem. I swapped the relay with the fog light relay. the fog lights still work fine but i plan to leave it that way to see if i get the service engine light again. im *hoping* that after the relay has power running through it for a while it heats up and stops working, which causes the check engine light. I do sit in about 2.5-3.5 hours of traffic per day, so the relay would have plenty of time to do that. My driving conditions are pretty much always dry though, living in southern california. If I don't get another check engine light I will just replace the relay, or else I will be back with what ive learned.
Old Aug 14, 2011 | 09:42 PM
hydrashocker
Sounds like a winner,
Please update when you get your results.
Old Aug 15, 2011 | 12:09 PM
johnnycraig
Well, it did not go as i had hoped. The service light came on again this morning on my way to work so it was not a power issue. I will have to wait until this weekend to do more troubleshooting because its dark by the time i get home at night. I will try testing ohms and power at the sensor itself. if i still cant figure it out, i will purchase the upstream o2 sensor and see what happens. will post results this weekend.
