oil pressure question
Old Aug 25, 2011 | 05:55 PM
  #21
Old_School's Avatar
Old_School
Or a write up......
Old Aug 25, 2011 | 06:24 PM
  #22
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
no offense, but if you cant reach up and unplug the oil pressure sensor and use a socket to thread it out and thread a new one in without a write up, you probably shouldnt be working on your own car, it was THAT EASY!!!!!!!!
however i AM going to take apart the old sensor so ill add some pics of that when i get it apart.
Old Aug 25, 2011 | 08:49 PM
  #23
srch4me's Avatar
srch4me
glad you got it fixed... and yeah... i see why you leave it at home
Old Aug 26, 2011 | 01:29 PM
  #24
adukart's Avatar
adukart
Wow that would suck not to have your truck at school, but $100 a month WTF? I'm glad my school is only 8 miles away, saves money on room and board.
Old Aug 27, 2011 | 02:00 PM
  #25
hydrashocker's Avatar
hydrashocker
LOL
That was a dead giveaway I agree when you were pressing on it and it would work then not. So as I read it, you pulled the harness apart and that is where the water was? Anyway this is the two way harness:
1 - K4 18BK/LB SENSOR GROUND
2 - G60 18GY/YL (4.7L) ENGINE OIL PRESSURE SENSOR SIGNAL
2 - G60 16GY/YL (5.9L) ENGINE OIL PRESSURE SENSOR SIGNAL
There was also the 1 wire lead.
I couldn't find a 3 way oil pressure sending switch harness?????
Old Aug 27, 2011 | 10:45 PM
  #26
shrpshtr325
THE ULTI-MOD
the 2002 factory service manual, it is in there bc i found the pinout for it
it has a 5v supply, a signal, and a pcm ground
and adukart, yes it does suck not having the truck at school but life is what it is.
Old Aug 28, 2011 | 07:08 PM
  #27
hydrashocker
My mistake, I thought from your postings that you had a 3 pin harness/sensor instead of the 1 or 2 pin connector.
Old Aug 29, 2011 | 10:18 AM
  #28
shrpshtr325
THE ULTI-MOD
you are correct the oil pressure sensor has 3 pins on it, 5v supply, signal, and pcm ground
you can also check page 949 of the 2002 factory service manual for the oil pressure sensor NGC
ENGINE OIL PRESSURE SENSOR (NGC) - BLACK 3 WAY
CAV CIRCUIT FUNCTION
1 K7 18OR 5VOLT SUPPLY
2 G60 18GY/YL ENGINE OIL PRESSURE
3 K4 18BK/LB SENSOR GROUND
Old Aug 29, 2011 | 10:37 PM
  #29
hydrashocker
I see,
I was looking at page 948 just above and never looked down......LOL
Thing is, I have never seen a 3 pin before, it's a strange option.
Old Aug 29, 2011 | 10:59 PM
  #30
shrpshtr325
THE ULTI-MOD
its only on the trucks with the next generation controller (NGC) which includes some very late my 2002 trucks and all 2003 trucks which have the 4.7 in them.
