Is there a way to make all the doors unlock when I get out?
Happens all the time. I get home form the store, hop out, go to the tailgate and it's locked. I can't recall a car in recent memory that didn't unlock them all when you put it in park, shut it off and open the drivers door. Is there a way to make this happen?
mike, you are driving a truck that is nearing 10 years old (03 would be about 9) it is NOT a recent vehicle, it also does not have a way to make it automatically unlock all the doors simply by opening the drivers door.
that said you MAY be able to buy an aftermarket alarm which controls locks which will let you do this
I do NOT recommend this as aftermarket alarms tend to cause alot of electrical problems.
My '02 SLT must be the oddball. As I pull away all the doors lock, and as soon as I turn the ignition off all doors unlock including the tailgate.
Well, just read a couple of posts back - I guess its due to the alarm. Sorry!
Trending Topics
you would have to reprogram the security module. or... you could think of ideas to mimic the I/O of the unlock process.. does the ignition send a signal (analog or digital??) when it is turned to the off position?? you may be able to run a jump wire from the ignition to the unlock toggle.. this is just playing with ideas.. not something i would do with my ride but if its a huge issue for you, go ahead and give it a shot..
