1998 to 2003 Rear Axle Swap
Old Sep 26, 2011 | 01:10 PM
  #21
FirePro911's Avatar
FirePro911
Brakes are a lot better over the drums. Only thing is, my booster leaks, so I need another one before I get the full effect.
I plan on ordering a rebuilt one I found online, once we get back from Cozumel in a few weeks.
Plus I love the look through the rear rims.
Old Sep 26, 2011 | 07:38 PM
  #22
FirePro911's Avatar
FirePro911
Done
See the build HERE
Old Sep 26, 2011 | 08:27 PM
  #23
laz45's Avatar
laz45
Looks the BOMB man.....Hey...Is that a center plug from your wheel? Cool idea...
I'm thinkin that little crash cage would have a place up top with the DodgeForum.Com decals if the admins would let ya,and if you felt like making them to sell.....I'de buy one....It looks wicked pissa neat......
Old Sep 26, 2011 | 08:38 PM
  #24
hydrashocker's Avatar
hydrashocker
Now that looks cool, although you covered your filler.
Old Sep 26, 2011 | 09:17 PM
  #25
srch4me's Avatar
srch4me
hell id buy one!
Old Sep 26, 2011 | 11:22 PM
  #26
adukart's Avatar
adukart
Three words, I WANT ONE
Old May 8, 2012 | 07:48 PM
  #27
RollerRed's Avatar
RollerRed
Hate to bring up a dead horse guys but quick question!
I have a friend that just killed his 03 D. He is parting it out and said he would give me his rear axle for $50!
My question...I don't use my E-Brake ever. In fact mine isn't hooked up because it was causing my rear's to drag(spring problem). Do I have to hook up the ebrake Or can I just unbolt everything and throw the 03 in no problem?
Also what gears came with the 4.7L in 03? He had a sxt if that helps any...Just seeing if I need to swap my rear gears as well as I have the 3.92...He also has an LSD and the brakes have 90% pad and new rotors!
Old May 8, 2012 | 08:38 PM
  #28
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
in 2003 the same two options were available for rear end gears (3.55 OR 3.92, you will need to check)
everything should bolt right up just fine, some have speculated that the distribution block would need to be replaced as well in order to remove allow the pressure to completly release on the rear brakes, but i have no confirmation on this.
Old May 9, 2012 | 01:07 AM
  #29
RollerRed's Avatar
RollerRed
Got it...I dont remember if they do, but do the rear axles have a mark or number on them to check? Or do I have to pull the cover and count the old fashion way?
Old May 9, 2012 | 09:11 AM
  #30
shrpshtr325
THE ULTI-MOD
normally there is a tag on one of the bolts, if that is missing just turn the wheels and count how many times the driveshaft goes by.
