oil leak mystery
Old Sep 19, 2011 | 12:40 PM
John92YJ's Avatar
John92YJ
Default oil leak mystery
ok I have 2001 4.7 2wd with just over 100k. noticed a drip and its not coming from the block but somewhere in the grill/bumper and I cant see where its coming from so before I start taking it apart I was hoping to get some incite on what it could be and or what to look for. not new to working on cars but is my first dodge. Thanks John
Old Sep 19, 2011 | 03:34 PM
master tech's Avatar
master tech
Site Moderator & Tech
Is it transmission fluid or engine oil?
Old Sep 20, 2011 | 01:03 PM
John92YJ's Avatar
John92YJ
ok took a better look and it is atf so guess I'm one of the many with a power steering leak hope its just a bad hose
Old Sep 20, 2011 | 01:27 PM
adukart's Avatar
adukart
If its coming from the bumper area check the trans cooler lines.
Old Sep 22, 2011 | 04:00 PM
John92YJ's Avatar
John92YJ
well just lost power steering and atf is all over
Old Sep 22, 2011 | 04:15 PM
adukart's Avatar
adukart
Sounds like you found the problem, unfortunately its the way you found it........
Hopefully its just a hose.
Old Sep 22, 2011 | 06:33 PM
John92YJ's Avatar
John92YJ
I know I should not of been driving it. dose atf evaporate? I think it might have been antifreeze
Old Sep 22, 2011 | 06:34 PM
hydrashocker's Avatar
hydrashocker
Not really? Antifreeze has a different smell and should be green I think in that year. ATF is red and has a different smell.
Depending on the hose, you might be able to have some new ones made at a hose shop like EVCO or a local shop. Also I have seen them in auto parts stores, dealer, and ebay.
