wheels and breaks
Old Sep 23, 2011 | 01:46 PM
Compactc9's Avatar
Compactc9
Originally Posted by srch4me
thanks hydra... when you say good rotor what do you mean... like a drilled and slotted rotor? or just a high quality one... and ill probably take your advice cause you know what your talkin bout
I haven't done anything to the brakes on my Durango yet, but on my Neon I have the drilled/slotted rotors, I noticed a big difference with them. I also will only use semi-metallic pads, I believe the ones I used were Duralast but its been long enough that I forgot. I definitely want to change the pads and rotors on my truck soon though, I don't like how the brakes feel and stop right now.
Old Sep 23, 2011 | 03:41 PM
adukart's Avatar
adukart
If you want a better braking, do the 2003 rear disc conversion, my $.02
Old Sep 23, 2011 | 04:01 PM
srch4me's Avatar
srch4me
that will be done eventually but for now just more expensive parts on the current brakes
Old Sep 23, 2011 | 04:24 PM
adukart's Avatar
adukart
Well then I would leave the rear alone until you do the conversion and just do drilled/slotted rotors and high performance pads up front.
Old Sep 23, 2011 | 05:08 PM
hydrashocker's Avatar
hydrashocker
Just what ever you like as far as rotors. I'm not the one to ask if slotted or drilled are better then this or that, I just use regular and have good luck with em. As far as the pad composition, the Duralast Gold series pads used to be a ceramic/semi metallic type. The best part about them is they don't dust, whereas even the regular ceramics still dust. The other thing I like about them is you can use them for hills and towing whereas the regular ceramic heat up and glaze and the Gold series don't.
Regardless, everyone I have convinced to try them love them, I haven't seen a unhappy member yet.......LOL......Knock on wood.
Now on the back, only 30% of braking goes to the back so I wouldn't do anything too expensive on the rears with disk, or drum for that matter.
Old Sep 23, 2011 | 05:39 PM
srch4me's Avatar
srch4me
yeah... the weight of the vehicle shifts to the front when you brake. ill have to try those pads
