ABS - Brake dash light on
Old Sep 24, 2011 | 05:03 PM
fastyz400's Avatar
fastyz400
Default ABS - Brake dash light on
Just wanted to add this in for those that have problems with ABS / Brake light trouble code.
Dodge wanted $130 to do a scan on my ABS system. I'm like WTF. I stopped in at a local brake shop, they wanted to scan my ABS system for free. I felt bad and tipped the guy $20. It turned out the Driver side front sensor went out. I decided to replace both since i was going to have my D jacked up.
I made the following video on how to replace your ABS sensor on a 2000 Dodge Durango.
http://www.youtube.com/watch?v=MaxuCOoKbfM
Old Sep 25, 2011 | 02:57 PM
IndyDurango's Avatar
IndyDurango
Thanks for the vid fastyz400.
SIDE NOTE FOR THE MODERATORS... move this to the Gen1 section. This is incorrectly in the Gen2 section.
IndyD
Old Sep 25, 2011 | 03:43 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Moved to correct section.
Old Sep 25, 2011 | 06:07 PM
WhiteWidow00's Avatar
WhiteWidow00
Keep in mind for the record, this is only for an ABS sensor issue. There are many more causes for a ABS/Brake light combination to come on, great video for replacement however.
Old Sep 25, 2011 | 07:50 PM
IndyDurango
WW00.... WB!
IndyD
Old Oct 5, 2011 | 10:58 PM
92blazada's Avatar
92blazada
just wondering, i have the same lights on in my 98. for some reason, the lights (abs and brake) go off when its a cooler temperature outside. it stays on when its pretty hot outside. would this affect the sensors malfunctioning?
Old Oct 6, 2011 | 01:15 PM
fastyz400's Avatar
fastyz400
Go to a local brake shop and get it scanned. The dealer wants way to much for a simple scan of your abs. When I say local, i don't mean the chain stores. They will try to screw you as well.
The brake shop i went to had a snapon scranner that was able to read my ABS codes. The left front had intermittent signal, according to the scanner.
I had replaced my wheel bearings with cheapo bearings which came with new ABS sensors about 5 month earlier. The bearings were fine, but the cheap ABS sensors failed. So, I replace both fronts with factory ABS sensors.
Old Nov 15, 2011 | 05:24 AM
dee0462's Avatar
dee0462
i just changed my front break n rotars on my 2000 dodge ram but my abs & break light still keep poppin on n off. i checked the break fluid n it was fine but i dont know how to locate my abs sensor to find out if thats the problem or not can any one help me with that please
Old Nov 15, 2011 | 10:32 AM
fastyz400's Avatar
fastyz400
1st off, you need to know if your ram is front wheel or Rear wheel abs only. Goto the brake shop like i suggested. They will tell you which wheel has the faulty abs sensor, or if there is something else wrong.
Old Nov 15, 2011 | 07:44 PM
ccthomp's Avatar
ccthomp
Remember that a faulty RWSS will cause those lights to come on or a bad wiring harness for the earlier models. Check that first.
