Ticking when in park
Old Sep 26, 2011 | 02:26 AM
ziggy's Avatar
ziggy
Default Ticking when in park
2002 Durango R/T 5.9.
A ticking noise coming from the motor when in park only. I thought it was the belt, so I replaced that. I also replaced the belt idler pulley. Any other ideas? it is still there. Belt tensioner maybe?
Old Sep 26, 2011 | 03:22 AM
srch4me's Avatar
srch4me
hmmm.... check your water pump. mine was ticking right before the pump failed on me.
Old Sep 26, 2011 | 07:28 AM
laz45's Avatar
laz45
I had to run mine with the belt off for a minute to isolate a noise between the engine and mounted accessories,only ran for about 30 seconds , no noise with the belt off.....My noise seems to be comming from the rear side of my a/c compressor....(long screw driver against the ear or a steth)
Not a good idea at all running with the belt off but it's a fast way to check things off the list....Did you run it before you installed the new belt and pulley?
Old Sep 26, 2011 | 11:06 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
+1 on running it without the belt on for a few minutes to isolate if its the engine or the accessories, just dont drive the truck with the belt off (and i would suggest doing it first thing in the am or at least on a cold engine)
Old Sep 26, 2011 | 12:00 PM
laz45's Avatar
laz45
Agreed sharp,I did the first in the morn start so I could hear the engine pump up
oil pressure also...def no driving...Hope some of this helps ziggy
Old Sep 26, 2011 | 12:03 PM
adukart's Avatar
adukart
I've got a slow a/c leak, and the a/c compressor ticks at idle when it gets low. I just turned off the a/c and it goes away.
Old Sep 26, 2011 | 08:36 PM
hydrashocker's Avatar
hydrashocker
Yep take off the belt and see if the noise is engine or pulley related.
Old Sep 26, 2011 | 08:39 PM
laz45's Avatar
laz45
First thing I do Just so I don't drive myself nuts hunting a noise....
Old Sep 27, 2011 | 09:53 PM
Kensai's Avatar
Kensai
my 5.9 makes a ticking clicking also. Traced the ticking to the passenger side. After listening to everything, I think it is my fuel injectors that is making the ticking/clicking noise.
Old Sep 28, 2011 | 12:07 AM
ziggy's Avatar
ziggy
Damper. A whole lot of fun to get to that.
