What is a code 63, please?!!!
Old Oct 3, 2011 | 03:13 PM
pwshep's Avatar
pwshep
Default What is a code 63, please?!!!
Hi folks,
Having some problems with my 2001 Durango SLT, and I'm hoping someone here can help.
My brakes suddenly got spongy, and both my brake light and ABS lights came on. I brought it to a shop and they hooked it up and got a code 63, but they don't know what that is. They said it is dealer-specific.
Can anyone tell me what this code means, and explain it?
Thanks in advance!
Old Oct 3, 2011 | 03:38 PM
vpnavy's Avatar
vpnavy
Welcome Aboard pwshep! Stay tuned - a Technician (or member) will jump in shortly to provide a possible solution. In the meantime, don't forget to browse Sub-Forums: Durango for stuff related to your ride.
While you are waiting for a reply - I searched the net and found: P0063 HO2S Heater Ctrl Circ Low Bank2 Sens3
Old Oct 3, 2011 | 05:17 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Welcome to Dodge Forum!! Enjoy the site!!
Dusty
Old Oct 3, 2011 | 06:21 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I moved this thread to the first generation Durango section,
FF
Old Oct 3, 2011 | 07:52 PM
laz45's Avatar
laz45
Did you see what they used to extract the code? What type or brand of scan tool? A lot of consumer level scan tools will not work on your truck,no matter what they tell you so it's important to know what they used.....The best is Dodge's DRB...
Closest I can tell is; 63- Rear Reset Switch Closed....
Old Oct 4, 2011 | 12:59 AM
master tech's Avatar
master tech
Site Moderator & Tech
Symptom:
REAR RESET SWITCH CLOSED - EBC 2
When Monitored and Set Condition:
When Monitored: CAB not in the antilock pressure control mode.
Set Condition: Reset switch voltage low and the when monitored conditions have been
satisfied for over 200 consecutive controller checks spaced 5 milliseconds (ms) apart (1.0
second total).
POSSIBLE CAUSES
REAR SOLENOID DTC(S) PRESENT
HCU 4-WAY HARNESS OR CONNECTOR DAMAGE
MECHANICAL BRAKE CONCERN
HCU INTERNAL CONCERN
TEST ACTION APPLICABILITY
1 Ignition on, engine not running.
With the DRBIIIt, read DTC’s.
Are there any DTC’s displayed for the Rear Solenoid Valves?
All
Yes ® Perform the appropriate diagnostics test for the displayed DTC’s.
Perform ABS VERIFICATION TEST - VER 1.
No ® Go To 2
2 Turn the ignition off.
Disconnect the HCU harness connector.
Note: Check connectors - Clean/repair as necessary.
Inspect the HCU harness and connector for damage.
Is there any HCU connector, terminal or harness damage?
All
Yes ® Repair the HCU 4-way harness or connector as necessary.
No ® Go To 3
3 Road test the vehicle and check mechanical brake operation.
Check whether brakes apply and release OK.
Is there a mechanical brake operation concern?
All
Yes ® Repair the mechanical brake concern.
No ® Replace the Hydraulic Control Unit in accordance with the
Service Information.
