Abs code reader
Old Oct 7, 2011 | 06:36 PM
jetuco's Avatar
jetuco
Question Abs code reader
my 99 durango 5.9 4wd/ 4wabs has abs and brake lights both lit. i have changed the switch on the rear end and the switch on the tranny. I have no problems with the brakes but i wanna see what the abs code is saying , then i wanna shut them off. Other than going to the dealer to have them use the DRB, I have heard that a snap-on code reader might be able to read these codes. I had and Actron unit and i checked into the innova OBDII models and neither one will work for my trucks abs codes. I have seen the Snap-on MT2500 readers boxes on ebay for reasonables prices, does any one know if this will work for my year with 4wheel ABS?
Old Oct 7, 2011 | 07:15 PM
adukart's Avatar
adukart
You're more than likely gonna have to contact the scan tool companies to see, other than that you might find a local shop that has one.
Old Oct 7, 2011 | 08:24 PM
pkucan's Avatar
pkucan
The snap-on that the AAMCO shop used to read my ABS code for free has a bunch of chips/keys for different vehicles. Be careful they are expensive!
Old Oct 7, 2011 | 10:20 PM
hydrashocker's Avatar
hydrashocker
Your better off asking a dealer to fix the issue or at least tell you what is wrong for $60 bucks and just bite the bullet.
