O2 sensor signal wire and vacuum
First question for a 1998 dodge durango what is the signal wire from the o2 sensor leading into the computer. I have a air/fuel ratio guage and all it does is jump from lean to rich none stop im guessing i have it hooked up to the wrong wire. And my second question is i have a vavuum guage also and at idle itll read 20 and at gaining speeds it drops to 0 which is normal but sometimes it reads poor vacuum what can e causing this. Thank you
The O2 sensors have, heat and readout going to the PCM.
Check your vacuum lines. Also there is a check valve right at the brake booster (where the main line plug in) that might need replaced. The second is inline and I think is at the main switch.
Im trying to hookup a air fuel ratio guage and the green wire onthe guage i have to hook it up to the wire that gives the conputer the signal from the o2 sensor and i mostly have bad vacuym when im drivin
