FOGGY WINDOWS, door panels.
Old Oct 18, 2011 | 01:43 AM
davebenn52's Avatar
davebenn52
Default FOGGY WINDOWS, door panels.
My wife just reminded me about another issue we are having with our Durango. When we run defrost the windows start to fog up. This just started after sitting for a while. I had to replace the transfer case so the D sat for about 2 months. I read somewhere there is a filter that may cause this and would much appreciate the location of said filter. I think it is in the interior some where. I also have a speaker blown in the dirvers sie rear door (very crappy sound) can some one tell me how to get the door panels off without destroying them?
Old Oct 18, 2011 | 08:18 AM
monster406s10's Avatar
monster406s10
To take the doors panels off there are 3 screws on the bottom of the door. One behind the inside door handle and behind the other handle that you use to shut the door. Then just pry the two sides and bottom of the door panel off with a screw driver or putty knife. Then lift the door panel up and take the rod off that goes to the door handle.
Old Oct 18, 2011 | 09:40 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
there is no cabin air filter in these trucks, but it sounds to me like you hvae moisture in the hvac system
Old Oct 18, 2011 | 12:26 PM
srch4me's Avatar
srch4me
could be your heater core too... any funny smell when you run it? anything that looks like smoke or steam come out?
Old Oct 18, 2011 | 04:27 PM
Dirtrango's Avatar
Dirtrango
+1 That would be my guess.
Old Oct 22, 2011 | 08:52 AM
jpankask's Avatar
jpankask
Default foggy windshield, smell and "smoke"
I have same issue and was looking for some leads on the problem/solution. Heater was not working for a while. Took it to a mechanic last year who said the heater core was blocked and he blew it out. Got a new water pump at the same time, as the old one failed. Now, when I run the defrost on anything but the coldest setting, there is a funny smell, something that looks like "smoke" coming out of the vents and the windows and windshield fog up.
srch4me, you asked those questions, I assume you've experienced that before and know the solution?
Thanks,
Jason
Old Oct 22, 2011 | 08:56 AM
shrpshtr325
THE ULTI-MOD
you know srch, your definitely onto something, i forgot about the heater core, jpankask, it sounds to me like you have a leaking heater core (it is blocked off from the airflow when you put the temp settings on the coldest setting)
Old Oct 22, 2011 | 10:45 AM
jpankask's Avatar
jpankask
Thanks. That gives me a good place to start. I have been slowly losing coolant for some time, but never see anything under the truck. Have to fill up with a cup or so of coolant every few weeks.
Old Oct 22, 2011 | 06:41 PM
shrpshtr325
THE ULTI-MOD
yea that makes it 99% that its the heater core
Old Oct 22, 2011 | 11:51 PM
hydrashocker's Avatar
hydrashocker
Heater core.
