03 SLT steering
Old Oct 20, 2011 | 08:34 PM
413drum's Avatar
413drum
Default 03 SLT steering
Hello Everyone,
First off, just want to say I am new to this forum.
Now to buisiness.
I recently got an 03 Durango SLT.
It has 90,000 miles on it (i got it cheap, just needed 4x4).
I had not heard to many bad things about durangos previous to purchasing it.
Now I am second thinking my choice.
When I am driving and hit a pothole or any large bump, my truck will jerk to the right/left. If i am going straight it DOES NOT happen. But when turning, It jerks whatever direction I am currently going.
I turned my wheels all the way on my driveway and did a visual inspection of the Ball Joints. They look good.
There also seems to be a little bit of a "dead zone" in my steering wheel.
Do you think this could be the ball joints or what?
If my problem is not clear, shoot me a message and I will try and explain better
Old Oct 20, 2011 | 09:36 PM
WhiteWidow00's Avatar
WhiteWidow00
Sounds like control arm bushings to me or possible a bad tie rod end.
When you say "jerk" do you mean it literally rips the wheel out of your hands or it just shifts to the side?
Old Oct 20, 2011 | 09:52 PM
413drum's Avatar
413drum
it does not "rip" to wheel out of my hands. It just shifts to that side suddenly. To the point where I have to correct it or I will go into the other lane. Does not happen often. Only on fairly large bumps.
This is my first SUV, so I am not sure it its the fact that the truck is just bigger than the little escort i used to have, or if it is infact a mechanical problem
Old Oct 21, 2011 | 12:11 AM
Compactc9's Avatar
Compactc9
Bumps seem to have the same affect on mine. It seems like I see other trucks and SUVs do the same thing when they hit the same things I do, I'd just say that its normal. Cars and trucks don't always handle the same.
Old Oct 21, 2011 | 01:48 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
its a factor of a leaf spring rear suspension on a solid rear axle, you can minimize the effects with good sway bar bushings and a good set of shocks, but you cannot (in my experience) completely get rid of it.
Old Oct 22, 2011 | 11:17 PM
hydrashocker's Avatar
hydrashocker
Sounds like inner tie rod ends. Most likely you have ware on the inside of the tires.
You have 90k on the truck and you are rethinking your decision on buying the truck because it has a slight issue, what did you expect a perfect in every way truck? It's slightly worn and has a few issues, deal with it. It's not like you just spent 30k on a brand dew truck?
Old Oct 22, 2011 | 11:30 PM
shrpshtr325
THE ULTI-MOD
damn jack chill out, he just has some learning to do
Old Oct 23, 2011 | 12:24 AM
hydrashocker
Just sayin man, besides the whiskey man has my number tonight, been off the band wagon for the last while.....LOL
Old Oct 23, 2011 | 12:04 PM
samnbensdad's Avatar
samnbensdad
Hate to add one more possibility to the mix, but ... It sounds pretty similar to the issue I was having before I replaced my intermediate steering shaft.
