1999 Rango low on power
Old Oct 25, 2011 | 12:22 PM
srch4me's Avatar
srch4me
have you cleaned the throttle body too? thats usually part of my tune ups. but like said our rigs are heavy... almost 5000 pounds if i remember correctly. our rigs have a frame. if im not mistaken your jeep will have a unibody making it lighter than a durango. tire size will also play a part in this as well.
Old Oct 25, 2011 | 05:24 PM
adukart's Avatar
adukart
I know mine weighs more than 5000, its closer to 5500. According to the scale at the local landfill that is.
Old Oct 25, 2011 | 09:48 PM
RollerRed's Avatar
RollerRed
On the title of for mine it says the scale weight is just over 4100lbs...But this must have been before fluids mabey...
Old Oct 25, 2011 | 10:12 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i believe the DRY curb weight is around 4800lbs for a 4x4
Old Oct 25, 2011 | 11:52 PM
brhodes's Avatar
brhodes
Yeah, I read somewhere 4060 pounds, also. My 'burban is 4600 and has 110 less horsepower.
Old Oct 26, 2011 | 12:13 AM
hydrashocker's Avatar
hydrashocker
Replace the transmission filter, adjust the bands, and fill with ATF+4 fluid only. Do not power flush it!!!!!
Old Oct 26, 2011 | 12:58 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Check the cat.
Check for the deathflash too.
Old Oct 27, 2011 | 03:15 PM
'RANGOMAN's Avatar
'RANGOMAN
Thanks everybody for the help. Cleaning TB and trans service are at top of list.
Recommendations for a HD tourq converter? What is a "deathflash" and how does one find it?
Old Oct 27, 2011 | 07:15 PM
hydrashocker
The "deathflash" is a update from the dealer that they flash into the PCM to offset a plenum gasket leak failure. It was a cheap fix to a bad design. This will only affect the 5.9L and 5.2L engine. If you have this flash a update sticker will be placed on the PCM or under the hood on the front clip.
Hughes makes a good convertor.
