HID's on the new D... what say ye?
Recently got a loaded up 03 Durango for my wife. I've never owned a dodge before, mostly chevys but seems to run well, nice and smooth compared to my 3/4 ton and looks pretty sharp.
She wants better lighting. How blinding are HID's in the stock housing on these rigs? I would go with 3000k or 4300k... Nothing higher than that. I would also like to replace the fog lights with HID's also....
Any problems with going with hids on the durangos?
Any suggestions?
Any suggestions?
I was looking in this direction:
http://www.vvme.com/search-result?ma...1&option_31=-1
I was looking into the digital slim, its a dual bulb, hid low and halogen brights... is this what I should be looking at?
Also, will the 893 work for the fog lights?
personally i would get clear housing if you are going with HIDs, the factory housings have a diamond shaped pattern in them that i would expect to really distort the HIDs, idk why they dont do it with the halogens, but then dont.
also make sure that the HIDs are aimed correctly once you put them in otherwise you will be guy that everyone else on the road hates for blinding them with your lows.
If you really want to save money though why not just clean the lenses and go with silverstar bulbs? The brightest ones are great, see perfectly in most conditions. And you wont be that guy that blinds every one! Plus it stays stock, so changing them is easy, and it is one bulb!
you definitely need crystal clear lenses (the ones that are clear like plexigalss not just the clear ones like mine) and to make sure they're properly aligned otherwise you could possibly be blinding everybody.
Also it is technically illegal to use hids (in most states at least) with diamond lenses (factory for us) that aren't designed for hids because of them blinding people. You need to go with crystal clear lenses otherwise if a cop wanted to be a dick he could write you a ticket.
last year I replaced my old yellowed lenses with new clear ones (and the orange corner lights with clear ones) and then put silverstar ultras in. Its amazing how much brighter they are and how much farther they go (on hi beam) than normal halogens, and they look better than crystal clear lenses to me at least
Trending Topics
I personally would go with this set up
http://www.streetbeatcustoms.com/Z/H...lights/818090/
yes they are not the stock housing but they are not to expensive and come with the bulbs and from what i have heard a bright as S#!t.
