Clunk clunk from fron end
Old Dec 3, 2011 | 03:54 PM
Rango02RT's Avatar
Rango02RT
Could it be in front diff?
Bottom ball joints loose...
LOL... I know all my question's .. I'm a chick!
Old Dec 3, 2011 | 03:56 PM
Rango02RT's Avatar
Rango02RT
Hub bearings? Are they supposed to make a noise?
Old Dec 3, 2011 | 04:51 PM
TurboStixx's Avatar
TurboStixx
as far as i know, no...
Old Dec 3, 2011 | 04:53 PM
that_guy's Avatar
that_guy
Originally Posted by Rango02RT
Ok took both cv axles out... driver side grease is black.. and passenger side is a greenish brown....
how do I tell if there bad?
i'm not entirely sure once they're off, but if theyre still on the vehicle and you can wobble them alot by hand, theyre bad
Old Dec 3, 2011 | 05:11 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if the grease is greenish brown id say its contaminated, means the boot on that CV is likely torn, if so that could very well be your problem, and if it isnt then it will be the problem before too much longer, you will need to replace that shaft at this point.
Old Dec 4, 2011 | 06:46 PM
Rango02RT's Avatar
Rango02RT
Drive line or t-case ....is my next... how long can I have the front drive line out just for temporary .....
Old Dec 4, 2011 | 08:16 PM
Rango02RT's Avatar
Rango02RT
Front drive line out ...put in 4hi... clunk clunk noise gone :-)
Think its time for a whiskey and coke
Old Dec 4, 2011 | 09:25 PM
shrpshtr325
THE ULTI-MOD
i would get it fixed ASAP driving without the front driveline completely installed seems like a bad idea to me
Old Dec 5, 2011 | 12:32 AM
Rango02RT's Avatar
Rango02RT
Are the 4x4 and AWD prop shafts the same length?
Old Dec 5, 2011 | 10:40 AM
shrpshtr325
THE ULTI-MOD
prop shafts? do you mean the driveshaft? (from t-case to front differential?) or the axle shafts (parts that have the cvs and go from the differential to the wheel)
if you mean driveshaft then yes they are the same part # in the parts manual
52105982AC
