washer fuild level sensor
Old Dec 11, 2011 | 12:57 PM
bblok572cid's Avatar
bblok572cid
Default washer fuild level sensor
in my 2000 durango slt 5.9l awd my washer fluid lever indicator lights comes on when i use my washer fluid but it is still full if i fill it but dont use the washer fluid it wont come on and say its low when its full any help would be great
Old Dec 11, 2011 | 06:55 PM
that_guy's Avatar
that_guy
check and make sure the wires going to the washer pump and level sensor are making good contact. If you're still having problems you'll probably need to replace the fluid level sensor. It's a $10 part on rockauto.com as is the pump if you end up needing that also
Old Dec 11, 2011 | 09:03 PM
dsolorio's Avatar
dsolorio
Doesnt the early model Ds have a washer fluid tank in the rear soley for the rear window? Im not really SURE about it, but if it does I would check the level in that.
Old Dec 11, 2011 | 10:49 PM
that_guy's Avatar
that_guy
my 99 has a separate tank for the rear. Do the 01 (i'm guessing 01 and up since thats when the "facelift" was done) and up durangos not have it?
I'm guessing that its not the rear tank that's causing the issue but i guess it never hurts to check the level in it. (usually rain water running down from the roof fills up the rear tank since the filler tube is in the jamb of the rear gate)
Old Dec 11, 2011 | 11:25 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the redesigned interior trucks only have one washer fluid tank, and its in the front
Old Dec 12, 2011 | 08:12 PM
dsolorio's Avatar
dsolorio
Yea, my 03 only has only one. I happen to notice the filler tank one day looking at a friends 99 but wasnt positive if it was the washer fluid. Then I forgot to ask about it. lol
Old Dec 12, 2011 | 11:22 PM
hydrashocker's Avatar
hydrashocker
The older style windshield washer tank in the rear does not have a level sensor, however the front ones do if equipped in both older and newer builds in the 1st generation.
Old Dec 13, 2011 | 12:47 PM
bblok572cid
I haven't checked but I think I only have one filler and its attached to my coolant tank above rad
Old Dec 13, 2011 | 02:11 PM
that_guy's Avatar
that_guy
they probably changed it in 2000 then ahead of the 2001 facelift
if you don't have one of these in the jamb of your rear hatch then the front and back must both run from the same tank
Old Dec 13, 2011 | 05:21 PM
srch4me's Avatar
srch4me
i had a problem similar to that and it ended up being that the sensor for the tank was floating upside down...
