Stereo help
Old Dec 28, 2011 | 10:05 AM
  #21
brutal23's Avatar
brutal23
Talking Nailed it!!!!
Well Thanks to all of your help, i found it! i pulled apart the pass side door panel and removed the speaker and turned on the radio and it works fine! when i tested the harness both wires are positvie meaning there is a short! now i will trace it back to find the short or just run a new wire. either way, holy hell! thanks again to you guys i got my radio back and didnt spend a dime (except for the $35 on a used OEM radio i bought on ebay) oh well...any body need an 02' RAM radio?
Old Dec 28, 2011 | 12:37 PM
  #22
brutal23's Avatar
brutal23
Default Thanks!
Originally Posted by topdogcustoms
pull the speakers to make sure one of the wires isn't grounding out the radio. I would also start looking for a amp or where there was an amp if there was no amp there shouldn't be a fuse
You were right buddy!! That fixed it...Tahnks again!!!!
Old Dec 30, 2011 | 11:46 AM
  #23
topdogcustoms's Avatar
topdogcustoms
No problem glad i could help
