Will P265/75R16's fit?
Old Jan 1, 2012 | 06:54 PM
ZCR1's Avatar
ZCR1
The optional factory size was 265/70/16 NOT 75.
Old Jan 2, 2012 | 12:55 PM
topdogcustoms's Avatar
topdogcustoms
you guys are wrong they will not fit unless you lift it
265/75/16= 32/10.43/16
265/70/16=31/10.43/16
Old Jan 2, 2012 | 02:03 PM
Compactc9's Avatar
Compactc9
Mine's got 31/10.5/16s according to the tires, as did my last one. No rubbing. 32's won't fit though.
Old Jan 3, 2012 | 09:51 AM
Instant Classic//'s Avatar
Instant Classic//
I would question the answers given, but look at who gave the answers my friend. Trust shrp
Old Jan 3, 2012 | 09:58 AM
topdogcustoms
Shrp is wrong on this one its a 2wd theres no way 32" tire is going to fit without a lift or lots of cutting i have a 4x4 and a 32 will not fit on mine without cutting thats why you do the t/s lift
Old Jan 3, 2012 | 10:02 AM
topdogcustoms
ZCR1 you are correct
Old Jan 3, 2012 | 12:06 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yea i typed in 75 when i meant 70, the 70s will fit on a 2wd just fine, but the 75s may rub at(never actually seen a D w/o 4x4)
Old Jan 3, 2012 | 03:21 PM
that_guy's Avatar
that_guy
I never did either until I moved to south carolina. down here its a about 50/50 split of 4wd and 2wd
Old Jan 4, 2012 | 09:38 AM
revvhigh's Avatar
revvhigh
Ok, so it sounds like the majority opinion has changed from 'they will fit' to 'they will rub'. I guess I am glad I am a procrastinator and had not put them on yet!
So here's my one follow up question: This 2WD Durango is driven 100% on paved streets. It is the family grocery getter and kid hauler. (I live in Houston Texas... I would say most of the Durangos I see are used that way. I probably see 5 2wd's for every one 4wd, if even that many.) Anyway.... what this means is, most of the time I will not be seeing a lot of wheel articulation. The biggest thing my tires will roll over will be speed bumps. So with that in mind... can anyone tell me if the rubbing under these conditions will be minimal/occasional and tolerable... or if it's just going to be plain unworkable?
I realize this setup may not be ideal but it would sure help my budget if I could use this free set of tires instead of shelling out at the tire store for a whole new set.
Old Jan 4, 2012 | 10:09 AM
shrpshtr325
THE ULTI-MOD
i have no experience trying this, but i would expect it to rub at lock in either direction (turning in a tight parking lot ect)and would probably be fine under most circumstances, however i cannot say that for certain.
