No Boom Boom
Old Dec 31, 2011 | 09:43 PM
  #31
DodgeGirl91's Avatar
DodgeGirl91
Just a reminder.. Durangos have ALOT of ground issues. I hooked up a amp and 12" sub in mine and I found myself moving the ground wire alot trying to find a constant connection. So if you have any more problems look at that
Old Jan 1, 2012 | 12:19 AM
  #32
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if you had ground problems with an aftermarket unit that was likely installer error, my 10 year old truck has had no ground problems at all (granted i dont have any aftermarket electronics installed). while it is a possibility in this case i wouldnt call them common
Old Jan 1, 2012 | 12:20 AM
  #33
TurboStixx's Avatar
TurboStixx
Not sure, I wasn't the original installer (just been fixing the rats nest of wires that was in there. As soon as I posted, I let the wife take the D to the store (she enjoys it WAY too much) and about half way to the store it cut on and has stayed on since apparently. Guess I need to do some major investigation and see if I can find the short, because I have narrowed it down to short or bad head unit.
Old Jan 1, 2012 | 12:26 AM
  #34
shrpshtr325
THE ULTI-MOD
its a short, the question is if it is in the head unit, or the wires going to the headunit.
Old Jan 1, 2012 | 12:27 AM
  #35
TurboStixx's Avatar
TurboStixx
I am starting to think Head unit, but I will figure it out. Thanks shrp for your help
Old Jan 1, 2012 | 11:51 AM
  #36
laz45's Avatar
laz45
I had a stereo in in my ramcharger that acted the same way,cuttin in and out and such. The whole issue was when the guy installed it he didn't use a dedicated case ground from the stereo,it was grounding through the antenna and that wasn't a very good contact.As soon as I ran a ground from the rear of the stereo it work fine and no more gremlins.I know some systems use a common ground in the harness for the speakers,not sure about the Durango Infinity but with all the wire you're finding maybe something there?Try running a new dedicated ground off the stereo and see if it helps...
P.S. maybe sharp knows if the speaks share a common ground or a wiring diagram in the FSM....
Old Jan 1, 2012 | 03:54 PM
  #37
Dirtrango's Avatar
Dirtrango
Hey stixx check out this website it's got lots of great info and you can learn a lot about car electronics here. http://www.the12volt.com/ hope this help you now and in the future, I love this site.
Old Jan 1, 2012 | 07:13 PM
  #38
TurboStixx's Avatar
TurboStixx
Thanks Dirt, awesome site!
I am not one to mess with the electronics on cars, always afraid I am going to snip the wrong wire! I wish I was more knowledgeable in the electronics, would love to hook up more lights to the D
Old Jan 1, 2012 | 08:33 PM
  #39
shrpshtr325
THE ULTI-MOD
im not sure about the common ground and all my manuals are on my external hd which is sitting in my dorm at school (im at home) so i cant really check for you right now.
Old Jan 1, 2012 | 08:36 PM
  #40
TurboStixx's Avatar
TurboStixx
Not a problem shrp, hope you are enjoying your break
