starting issue
Old Jan 1, 2012 | 06:39 PM
mnshine04's Avatar
mnshine04
Default HELP HELP HELP STILL HAVING starting issue
Can anyone help me with a starting issue i am having with my 99 Durango? 5.9L 4x4 133000...
Old Jan 1, 2012 | 07:17 PM
TurboStixx's Avatar
TurboStixx
Can you give us a little bit more information. Engine Size (4.7, 5.2, 5.9), 4x4 or 2x4? And what exactly is it doing?
Old Jan 1, 2012 | 08:03 PM
mnshine04's Avatar
mnshine04
It is a 99 with a 5.9 133000 miles, i have replaced the folowing to avail. new coil-wires-cap-rotor-cam position sensor-crank position sensor
Old Jan 1, 2012 | 08:05 PM
mnshine04's Avatar
mnshine04
it turns over just fine but will not start, it will give a slight put put then nothing. The previous day is was just fine. It is a 4x4
Old Jan 1, 2012 | 08:38 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
do you have voltage at the coil? what about fuel pressure? any spark? (pull a plug and hold it to the block while plugged into the wire and have some crank the engine over, check for spark at the plug)
Old Jan 1, 2012 | 08:56 PM
that_guy's Avatar
that_guy
it wouldn't hurt to check the battery connections either. If they're dirty they could cause issues with the computer and possibly keep it from running even though you can crank it.
Old Jan 1, 2012 | 09:06 PM
mnshine04's Avatar
mnshine04
It does have good spark. I was told by someone else that the timeing may have jumped. Is this possable? The fuel presure is also good.
Old Jan 1, 2012 | 09:13 PM
TurboStixx's Avatar
TurboStixx
I think it is possible the timing jumped, though I feel your issue is going to be far less serious than that.
+1 that_guy
Check that battery!
Old Jan 1, 2012 | 09:43 PM
that_guy's Avatar
that_guy
I very very highly doubt that the timing jumped. These engines all have timing chains which are very durable, and I believe that the 5.2s and 5.9s (not sure on the 4.7s) have metal sprockets for the timing chain. So again I would almost guarantee that the timing hasn't jumped
Old Jan 1, 2012 | 10:15 PM
shrpshtr325
THE ULTI-MOD
i wont say it cannot happen, but it is very rare for a timing chain to jump time, they last the life of the motor and beyond in most cases (i have NEVER seen a timing chain jump), also if a it had jumped time by only a bit it would still run.
check the crank or pickup sensor.
