Low oil and condensation
Old Jan 5, 2012 | 08:27 PM
fielder87's Avatar
fielder87
Default Low oil and condensation
Hey there.So today I went to check my oil and noticed it was low(1/4) on dipstick.When going to put oil in I noticed my cap was filled with slimmy sluge looking crap.Never seen this much before.The filler neck is also coated good.I cleaned and filled,ran for a bit and checked.it seemed a little better tho.Could low oil cause this or would it be head gaskek going?>Thanks
Old Jan 5, 2012 | 08:30 PM
TurboStixx's Avatar
TurboStixx
If it is on the dipstick/filler neck, that is not a good sign. Is it actually on the dipstick or just the filler neck? If it is not on the actual dipstick, then it is probably condensation.
Old Jan 5, 2012 | 08:54 PM
fielder87's Avatar
fielder87
It wasn't on the dipstick,just the filler neck and cap full!After thinking about it I think lack of oil and cold Canada weather, might cause worst signs I have seen of condensation build up ever.but not too shure...
Old Jan 5, 2012 | 10:52 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
as long as it was NOT on the dipstick it is just caused by condensation in the filler cap, and a lack of long trips, my guess is you use the truck for a lot of shorter trips which done let it warm up all the way (or just let it warm up all the way), if you do more long distance driving the engine will run hot long enough to boil it all out.
Old Jan 5, 2012 | 10:58 PM
TurboStixx's Avatar
TurboStixx
Yeah it only gets down to like 15 here and that is like 5 times a month and i have it on the fill cap
Old Jan 5, 2012 | 11:02 PM
shrpshtr325
THE ULTI-MOD
the 5.2/5.9 usually only get it when the PCV is bad, the 4.7 is the one which commonly gets this build up.
Old Jan 6, 2012 | 08:07 AM
fielder87's Avatar
fielder87
Ok also i'm running at 18.2l/100km would that be my 02 sensor bad and not throwing code?\
Old Jan 6, 2012 | 09:55 AM
shrpshtr325
THE ULTI-MOD
got that in MPGS???
13+ around town id say dont worry about it
16+ highway id say dont worry about it
if it was a sudden large drop then yes maybe the O2 sensor
Old Jan 6, 2012 | 11:13 AM
Bobman's Avatar
Bobman
Originally Posted by shrpshtr325
got that in MPGS???
Hmmm..... that would be 4.80793 gallons over 62.1371 miles, or 12.92387784347942 MPG
I'm bored today, can ya tell?
Bob
Old Jan 6, 2012 | 01:44 PM
shrpshtr325
THE ULTI-MOD
yea that is on the low side then checking out the O2 sensor is a good idea.
