Surging/slipping
Old Jan 11, 2012 | 08:08 PM
Freedog's Avatar
Freedog
Default Surging/slipping
Yesterday I drove my 2003 Durango (4.7) to pick up some tires at the coast. The drive was about 1.5 hours each way. During the drive back, I noticed that the engine was surging between 600 to 1000 RPM when stopped at stop lights. I figured that my need to clean the IAC was finally catching up with me. Halfway through the drive home felt like either the torque converter was locking and unlocking or the tranny was occasionally slipping. After much thought and yacking with fellow motor heads, I'm suspecting that the TPS might have checked out but I don't have a CEL. Has anyone had a similar problem and if so, what was the fix?
Old Jan 11, 2012 | 09:00 PM
TurboStixx's Avatar
TurboStixx
I had somewhat of a similar problem and it definitely was the TPS. When driving, the truck would literally feel like a boat motor with all the surging/slipping while driving. It also had the weird/jumping at idle. I replaced the TPS, then reset the PCM and good to go!
Old Jan 11, 2012 | 10:46 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the TPS does not always throw a code when it goes bad, replace it and reset the computer, we can go from there if the problem persists.
Old Jan 11, 2012 | 10:48 PM
otgarzā's Avatar
otgarzā
My TPS went out and i had no CEL i had cleaned the throttle body as well as the IAC and i proceeded to change the TPS thinking it was the next possibility and sure enough it fixed the problem
Old Jan 12, 2012 | 12:36 AM
TurboStixx's Avatar
TurboStixx
+1 shrp, i completely forgot to say that when the TPS (or another sensor) goes bad that it doesnt always throw a CEL, I hade 3 codes last time i checked(with no CEL on) and it was all sensors bad or unplugged
Old Jan 12, 2012 | 08:21 AM
Freedog's Avatar
Freedog
Cool, thanks for the help. I'm gonna change the TPS and see if that fixes the issue.
Old Jan 12, 2012 | 02:53 PM
TurboStixx's Avatar
TurboStixx
Just remember to reset the PCM, otherwise, even if that is the problem, you won't know!
Old Jan 12, 2012 | 03:24 PM
otgarzā's Avatar
otgarzā
I seem to always forget that when im in a hurry to fix something lol
Old Jan 12, 2012 | 09:47 PM
Freedog's Avatar
Freedog
I replaced the TPS and all is right with the world
Old Jan 12, 2012 | 09:48 PM
otgarzā's Avatar
otgarzā
Glad to hear the problem has been taken care of
