i know its been asked still have ??
Old Jan 20, 2012 | 08:47 PM
moparman_2004's Avatar
moparman_2004
Default i know its been asked still have ??
on my 99 durango after the turn signal is on for a few min it stops flashing and stays lit so i got a new flasher and they say some are behind the fuse panel then some are in the fuse panel and there was a slot in the fuse panel that the flasher fit but there wasnt one there before so im a bit lost on if its in the right section
Old Jan 20, 2012 | 09:07 PM
otgarzà's Avatar
otgarzà
Have you checked behind the fuse panel right above the obd2 port?
Old Jan 20, 2012 | 10:14 PM
that_guy's Avatar
that_guy
that's where it is on my 99 iirc
Old Jan 20, 2012 | 10:16 PM
TurboStixx's Avatar
TurboStixx
Exactly where it is on my 99...do I need to go out and take a pic? Gladly will for ya
Old Jan 20, 2012 | 11:01 PM
moparman_2004
if you would that would help alot cause it fit into a slot in the fuse panel were others say theres is but there was nothing there before so if you could get me a pic that would be great
Old Jan 21, 2012 | 12:37 AM
otgarzà's Avatar
otgarzà
Yeah it is behind the fuse panel have to get under the driver dash side and look straight above the parking brake. Picture would help to see it clearly.
Old Jan 21, 2012 | 01:41 PM
hydrashocker's Avatar
hydrashocker
Get on your back and look up under the dash on the drivers side above the E-brake yet right behind the main fuse panel. The hidden panel is literally right behind the main panel on the drivers side dash.
Originally Posted by hydrashocker
Well the regular cigarette lighter fuse in the ash tray should be in the regular panel. It could be the lead going to it. Pull it and start testing.
Here are some pic's for the hidden fuss box that might help everyone. Taken from here: https://dodgeforum.com/forum/1st-gen...or-lights.html
Here is my '99's.. Has two fuses back there. I'm sure the '98's are similar to the 99-00. Your guess is as good as mine as to what they control.
Old Jan 22, 2012 | 07:01 PM
moparman_2004
Finally got it done and don't wish having to do that on anybody what a pain in the *** if u have big hands
Old Jan 22, 2012 | 08:43 PM
Gambit505's Avatar
Gambit505
D*mnit mine started to do this... looks like all be replacing mine soon.
Old Jan 22, 2012 | 10:04 PM
TurboStixx's Avatar
TurboStixx
Luckily my fuse block has a fuse puller on the cover, makes it easier to get those little buggers! Glad you got it fixed, let us know Gambit if it doesn't fix yours!
