Another Speedometer, ABS and Brake light issue
First I have a 2001 Durango SLT. I have seen Other posts about this issue and some solutions. As stated in other posts, I changed the speed sensor in the differential. The speedometer actually worked again for about half a block.
At this point it was like the brakes automatically engaged and it made a squealing noise for a few seconds. The speedometer stopped working again and the check engine light came on. The brake and ABS light comes on if I drive it but isn't on each time I start it. The code for the check engine light is P0500, which I know is the speed sensor issue.
On a side note, was this year Durango equipped with keyless entry or was it offered as an option?
UPDATE: I replaced the output speed sensor, input speed sensor, and the ABS speed sensor again. The ABS speed sensor I had just put in a couple days ago had a piece of the plastic housing missing when I removed it.
I still have no speedometer. I didn't drive it very far so no lights came on.
I am at a loss and worried about driving it anymore with the possibility of a chunk of plastic in the differential. Any suggestions would be greatly appreciated.
I would open the differential up (good time to change the fluid) and check with a flashlight if the piece of plastic is in there. Only way to check unfortunately :-(
After you replaced all the sensors did you reset the PCM? Might be the reason you don't have speedo, not sure. Be sure to check the connections to the ABS Speed sensor.
Trending Topics
you definitely have to open up the rear diff and get the piece(s) out of there, if you dont it could chew up the gears(i am going with the assumption that there is more than just plastic broke off since something had to hit and damage the sensor).
You need to drain the fluid and clean out any debris and refill with fresh fluid, hopefully whatever is floating around in there did not take out another new sensor
