mysterious coolant leak
Howdy fellow dodge owners I seem to have a mystery on my hands maybe someone could point me in the right direction. I have a 99 durango 5.9l about 10 days ago I was having overheating problmes and when I popped the hood I had coolant running out from the bottom of the water pump. I replaced the pump and figured I was golden but I seem to be leaking about a gallon of coolant a day now. I dont see it comming from the water pump, upper or lower hose, or anywhere that I can see. There is a small amount comming out of the hose on the top of the water pump, (I think the heater hose) but it doesnt appear to be enough to cause the fluid loss I'm having. I am able to see it drip from the bottom and I'm able to tell it's in the front of the vehicle but I'm totally at a loss to see where it's comming from, when I look in from the top I can see a lot of coolant all over but I don't see a stream or a drip anywhere. Any help you could give me, places to look, parts to remove, possible cause, anything will help, thanks guys...
Oh, and an after thought it also runs at about 170 degrees I'm not sure what thermostat is in it and I've gotten a new 192 tstat that I'll replace once I get the above figured out I know heater cores in this model are garbage when they are this old I'm assuming it's not a project for non mechanic like myself. If I could get your thought on this as well it would be much appreciated.
Actually today when I checked it the engine was hot because my wife had just gotten home. I looked in the front and both sides with a flashlight for about 20mins with the engine running trying to catch the culprit. The only place I could find any fluid come out of at all was the bypass hose which quickly evaporated and wouldn't really come out unless i wiggled it. I'm sure it's because of heat but really there wasnt fluid on the pullys or anything just all around on the bottom under the radiator. Would there be enough pressure while it's being driven to push out enough fluid there to creat the kind of coolant loss I'm having? Tomorrow I'll pull the water pump back off and get the ac and alternator off and dbl check everything I'm not sure what else to do not being able to see the flud comming from anywhere is frustrating. Just guessing but I changed the water pump and now fluid is still comming out the safe bet is I didnt do it right rather than there just all of the sudden be another problem with the same system.
As far as the front of the vehicle fluid could leak from the hoses, the water pump and? or is that it? Assuming it's not running out of the radiator itself
Hmm well if its under the radiator make sure to check that for any visible cracks also check around the thermostat for leaks. The heater hose...is it loose on the clamp or it leaks because it has a slit in it? And is it still overheating? and im assuming that there is no coolant leaking from or around the water pump. It is normal for the coolant to evaporate when it leaks out when the engine is at operaing temp or higher so that maybe where its disappearing.
Trending Topics
I meant to get a new o ring for the heater hose but I didn't, I REALLY hope thats the issue but I doubt it. I didnt do the bypass hose because when I did the pump I didn't remove the ac/alternator because I figured I'd never get it all back on right I'm not all that mechanical. I'll toss a few new clamps on the hoses, and get that o ring installed and give it a day if not I'll tear it a part and hope for the best. It's SOOOO frustrating to know it's leaking but only while I'm not looking LOL I suppose I could stick a video camera in there and then it shouldn't ever leak right? cuz I'll be watching .
