Little Help
Old Jan 28, 2012 | 08:26 PM
PRFISHBAR's Avatar
PRFISHBAR
Default Little Help
Hey Guys,
I haven't been on the forum for some time since the Durango has been really good to me. I do have a small issue. I can't get the glove compartment open! Is there a lock in the 99 D that I'm not aware of? I doesn't feel like the latch is broken, it just will not pull open.
Any thoughts?
Thanks..
Old Jan 28, 2012 | 10:42 PM
master tech's Avatar
master tech
Site Moderator & Tech
If there is a key hole in the handle of the door? Or you may have something just jamed in the latch.
Old Jan 28, 2012 | 10:55 PM
that_guy's Avatar
that_guy
I don't think any of them had locks. Mine got stuck open once and I had to replace the mechanism. See if you can either reach up from under the dash (not sure if you can) or use something flat to slide in from the top and release the latch
Old Jan 29, 2012 | 02:30 AM
otgarzā's Avatar
otgarzā
That would probably be the best thing to do or try to shake it around until it opens or becomes dislodged if something is stuck in there. Also isnt there a way to unbolt the door without it being open?
Old Jan 29, 2012 | 10:42 AM
PRFISHBAR's Avatar
PRFISHBAR
I guess I'll try all of the above.
Thanks
