2002 Durango Fuse
Old Jan 30, 2012 | 06:32 PM
Amee Young's Avatar
Amee Young
Default 2002 Durango Fuse
Hi
Just bought 02 Dodge Durango and when we got it home hubby noticed that the high beam is not working. He was going to check the fuse box. He found the box but he can't figure out which fuse controls the high beam or the lights. He doesn't have the volt meter to check all fuses. If some one can tell us would be great.
Thank you
Old Jan 30, 2012 | 06:40 PM
that_guy's Avatar
that_guy
I'd think that would be the multifunction switch (turn signal, wipers, high/low switch) rather than a fuse.
Old Jan 30, 2012 | 07:24 PM
mikeismadness's Avatar
mikeismadness
I don't think there is a fuse for just high beams. Check to make sure the high beam in the bulb is good
Old Jan 30, 2012 | 08:38 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
only one bulb in these assemblies, high and low is in the same bulb.
Old Jan 30, 2012 | 09:08 PM
otgarzà's Avatar
otgarzà
Yup dual filament bulbs. Check to see that they arent burned out. Other than that it can be the multifunction switch. Is there a relay for the lights similar to the flasher on these trucks or no?
Old Jan 30, 2012 | 09:34 PM
mikeismadness
I believe there is a relay under the hood but I'm not 100% sure. It could be different tho since it has daytime running lights
Old Jan 30, 2012 | 09:37 PM
mikeismadness
Edit: my 2000 r/t doesn't have a headlight relay under the hood
Old Jan 30, 2012 | 11:35 PM
hydrashocker's Avatar
hydrashocker
There should be a headlight relay in the PDC under the hood. Look under the cover and there is a full diagram telling you were to look. Simply swap it with one of the same number like the horn.
Well I'm looking at the PDC in the service manual and it does not show a headlight relay???? And after reading the wire schematics it doesn't show it either???? At this point I would say either a multi-fuction switch or a bad fuse in the drivers side dash fuse panel at number #9.
Old Jan 30, 2012 | 11:40 PM
mikeismadness
Ya I actually went n had to look under my hood to see if there was a relay lol. I changed my fuses for both headlights the other day and didn't see it on the lid either.
