headlight bulbs
Old 02-10-2012, 02:16 PM
Augie Dog's Avatar
Augie Dog
Augie Dog is offline
Thanks that guy! I was just looking on Amazon for the different bulbs mentioned here and Amazon said the Philips Xtreme power bulb will not fit my "D".
  #32
Old 02-10-2012, 02:40 PM
otgarzā's Avatar
otgarzā
otgarzā is offline
For yellow lights you can check out the PIAAs and Hellas
  #33
Old 02-10-2012, 02:56 PM
Old_School's Avatar
Old_School
Old_School is offline
OEM fog/driving lights are # 899 IIRC
  #34
Old 02-10-2012, 03:48 PM
that_guy's Avatar
that_guy
that_guy is offline
This one on Amazon says it will fit
  #35
Old 02-10-2012, 04:20 PM
otgarzā's Avatar
otgarzā
otgarzā is offline
http://www.amazon.com/Optilux-H71071...8908499&sr=1-1
these are some yellow ones i found...different # but should fit the fog lights
  #36
Old 02-11-2012, 01:02 PM
Old_School's Avatar
Old_School
#899 is the OEM bulb number... #880 is the aftermarket bulb number..... For the fog/driving lights
  #37
Old 02-11-2012, 09:03 PM
otgarzā's Avatar
otgarzā
otgarzā is offline
You could also look into the 893s by hella. There is a difference between all these bulbs tho...as in lumens and wattage. Lemme look this up and i will update. But im pretty sure they all fit the set up. Has anyone else tried using any of those bulbs. I hear some people run silverstar 893s in place of the 899s. But out of personal experience i have not tried it nor do i know the success or failure that this may cause.
  #38
Old 02-12-2012, 12:33 AM
otgarzā's Avatar
otgarzā
otgarzā is offline
I found that the 893 and 899 both run with 37.5 watts while the 880 runs on 32 watts. The lumens are in the 500s for the 880, 700s for 899, and 900s for the 893. Now i believe these three lights also have the same connection type pgj13. They should also be the same length. Now i searched online and there are other people who have switched between these bulbs with good results. Here are the 893s http://www.amazon.com/gp/aw/d/B002E2...9024645&sr=8-2
  #39
Old 02-12-2012, 12:56 AM
otgarzā's Avatar
otgarzā
otgarzā is offline
I looked for piaas and they dont make yellows for the 800 series. Now i also remembered that i heard somewhere that people would put covers on their headlights/foglights to change the color and i found this which could also be an option.
http://www.lamin-x.com/Automotive-Products-s/47.htm
  #40
Old 02-21-2012, 01:21 AM
otgarzā's Avatar
otgarzā
otgarzā is offline
Quick Reply: headlight bulbs
