Windows wont go down or up?
Old Feb 1, 2012 | 09:47 AM
markus093's Avatar
markus093
Default Windows wont go down or up?
so at first the passenger side was being wonky and then it stopped, then the driver side etc and then the 2 rear windows now aswell, it would go down then i couldnt get it up (lol) for every window and they basically all stopped totally within about a month.
Any suggestions?
im thinking the driverside main switches?!
Old Feb 1, 2012 | 01:10 PM
that_guy's Avatar
that_guy
yeah, sounds like the drivers side master switch went bad. Replace it and you should be good to go
Old Feb 1, 2012 | 01:28 PM
markus093's Avatar
markus093
That's exactly what I was thinking but what's weird is that the window switches for each window on each door weren't even working aswell, so does that just mean that since the driver (main switch) is fried all the others are on the same circuit?
Old Feb 1, 2012 | 01:46 PM
that_guy's Avatar
that_guy
all the other switches have to go through the master switch (for the lockout function) so if the master switch stops working the slave switches won't work either. They should still be fine.
Old Feb 1, 2012 | 01:47 PM
markus093's Avatar
markus093
Ok amazing! Thx for your help!!!
Old Feb 1, 2012 | 02:10 PM
that_guy's Avatar
that_guy
no problem, hope you get it fixed
