Weird noise from front end while steering
Old Feb 7, 2012 | 03:32 PM
Nicholas Frenier's Avatar
Nicholas Frenier
Question Weird noise from front end while steering
Im new here and i have an issue maybe.. 02 durango slt plus awd with the 360. when i go to make a u turn theres a weird noise coming from the front. i know the rack is good had that checked out. just replaced to power steering lines. the pump is going but its not that bad yet. any idea? please help
Old Feb 7, 2012 | 04:36 PM
TurboStixx's Avatar
TurboStixx
What Kind of weird noise? Clicking, squeaking, squealing, rapid breathing, yelp?
Old Feb 7, 2012 | 06:31 PM
Nicholas Frenier
its hard to explain its like a click kind of noise
Old Feb 7, 2012 | 06:37 PM
mikeismadness's Avatar
mikeismadness
I'm going with ball joint, tie rod, or cv axle popping
Old Feb 7, 2012 | 09:27 PM
Nicholas Frenier
well the noise stopped now if it starts to act up again ill look cause ball joints were just replaced and one tie rod was replaced
Old Feb 7, 2012 | 11:20 PM
TurboStixx's Avatar
TurboStixx
Betting it is your other tie rod
Old Feb 8, 2012 | 10:34 AM
Nicholas Frenier
thanks for all the help now i got yet another issue, the damn thing wont shift outta park unless i manually push the lock lever in, im thinking i should lube it with pb blaster and let it work itself in to the contact points, apparently the recalls have been fixed but im gonna call them again to find out
Old Feb 8, 2012 | 04:20 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
dont use pb blaster as it is NOT a lubricant, it is a solvent/cleaner. Use a silicon based lubricant as it will hang around longer and not get tacky as it dries (which pb blaster and wd 40 both can do)
