Weird idol problem
Old Feb 12, 2012 | 08:01 PM
JSavinoJr's Avatar
JSavinoJr
Default Weird idol problem
So when i first drive my car the car idols weird when i am coasting before a stop. At night the dash lights will dim and the blower will slow down for a second as the idol drops. It stops doing this after driving for about 15 min. Could it be a bad idol position sensor? I changed it about a year ago,but it's an electric part and who knows how long they will last these days.
Old Feb 12, 2012 | 08:35 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
how old is your battery? sounds like a battery is getting week and once it gets some run time to recharge the battery after starting.
Old Feb 12, 2012 | 08:43 PM
adukart's Avatar
adukart
+1 shrps, sounds like a battery
Old Feb 12, 2012 | 08:59 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would agree with the battery, But would also add. Check the charging system, And was the idle speed sensor a aftermarket or a mopar?
Old Feb 12, 2012 | 09:08 PM
that_guy's Avatar
that_guy
+3 on the battery. You could start with checking the battery terminals for a clean connection also
Old Feb 13, 2012 | 06:59 AM
JSavinoJr's Avatar
JSavinoJr
The battery is new. The sensor is after market.
Old Feb 13, 2012 | 02:13 PM
adukart's Avatar
adukart
Load test the battery and clean the terminals real good. You should use a genuine mopar sensor from the dealer, aftermarkets tend to be hit and miss.......
Old Feb 13, 2012 | 07:34 PM
hydrashocker's Avatar
hydrashocker
Check your voltage on the gauge when you come to a stop and see if it drops. If it does it could be a alternator, or a battery temp sensor under the battery.
Old Feb 13, 2012 | 11:49 PM
master tech
I would replace both the idle speed motor and TPS with mopar parts. And remove the throttle body and clean.
