I have a 98 Durango and it's overheating. I've replaced the heads and gaskets, thermostat, and flushed the radiator. It overheats when I drive it but not while idling. My oil doesn't have any coolant. Any idea as to what this could be?
Thanks for the replies guys. I was told this morning that it was the block and was worked up all day about it. Pressure tested it and it's good. So tomorrow I will check the fan clutch.
Well I checked the fan clutch. I can rotate it more than half way and it's wobbly so going to replace it. Probably going to replace the water pump as well.
