Sudden loss of power
Old Mar 1, 2012 | 11:56 PM
  #21
otgarzā's Avatar
otgarzā
Yeah try the tps its cheaper and easier to replace. Reset the pcm and go from there.
Old Mar 2, 2012 | 09:40 PM
  #22
Iansmith45's Avatar
Iansmith45
Replaced the TPS and reset the PCM. We'll see how it runs.
Old Mar 3, 2012 | 04:19 PM
  #23
Iansmith45's Avatar
Iansmith45
TPS didn't solve the problem. Happened again this morning. This time I drove about a 1 mile and stopped at a red light. I tried to accelerate and it had very little power. It was jerky. I was able to pull over. The idle was kind of moving up and down between 500 and 1000 rpms. Waited for about 2 minutes and it seemed to e normal and was able to drive it to where I was going. Any thoughts. Try CPS now?
Old Mar 4, 2012 | 08:29 PM
  #24
neilb's Avatar
neilb
It's a real pig to be spending time and money on replacing this or that when you cant realy diagnose the problem for shure, but it sounds a lot like the problem I had with mine when the CPS went out, thats about all I can tell you, good luck with it mate, hope you get it sorted.
Old Mar 5, 2012 | 05:48 PM
  #25
Iansmith45's Avatar
Iansmith45
Took the Durango into my mechanic today. He said there was a crack in one of the vacuum hoses and another one had come off. They said this could be the cause. I guess we'll see.
Old Mar 5, 2012 | 10:40 PM
  #26
hydrashocker's Avatar
hydrashocker
Well it would sure make it run like crap, but to bog down that bad must be a large hose?
Old Mar 8, 2012 | 03:37 PM
  #27
Iansmith45's Avatar
Iansmith45
Ok so the vacuum hoses were not the problem. Just did it again. It only seems to do it when I press the gas pedal. Never when I am just cruising or stopped.
Old Mar 19, 2012 | 12:19 PM
  #28
Iansmith45's Avatar
Iansmith45
Today I started up the Durango and let it warm up as I scraped the ice off the windows. As I was doing this I noticed that it started to run a little rough and there was a lot smoke coming out of the exhaust. I looked at the tach and saw that RPMs going up and down between 500 and 1000. I turned the car off and let it sit for a min and then started it back up. Fired up fine and ran fine on my way to work. Any thoughts?
