99 5.2 electrical problems
Old Apr 7, 2012 | 02:35 PM
Nutlane2315's Avatar
Nutlane2315
It's been a while since I've messed with the truck, I have no spark at the coil. Recap, I have replaced the crank sensor, ignition pickup in the distributor, rotor, coil, i have no spark, fuel is fine, What do I do next? Pull the comp? Can I get that tested somewhere?
Old Apr 9, 2012 | 04:27 PM
hydrashocker's Avatar
hydrashocker
If you did not unhook your Negative battery cable before you replaced the or cam crank sensor it will fry the new sensor.
