Creaking and popping noise from front left
Old Mar 12, 2012 | 10:28 PM
lbzrango's Avatar
lbzrango
Default Creaking and popping noise from front left
Soo went and did some light trails today in my 00 rango, got stuck pretty good, there were massive ice bolders in the pond I went into. Ripped up my front bumper pretty good. And when I finally got out my front end was making a dirty popping creaking noise. But only when I turned left. So when I got home I checked the ball joint, wheel bearing, tie Rod End. And everything seemed fine.
I did some Google searches and I seen stuff about the mid shafts and or the allignment. Has anyone had this problem? And if so what was the fix?
Old Mar 12, 2012 | 11:15 PM
mikeismadness's Avatar
mikeismadness
Regrease everything. After any 4 wheeling u should really change the diff fluid and regrease everything. Although making ur alignment good again isn't a bad idea
Old Mar 13, 2012 | 12:10 AM
jmess's Avatar
jmess
check your cv axels as well. there shouldnt be any play in them. just grab it and wiggle. the first one i blew was on some easy trails and would have never expected it.
Old Mar 13, 2012 | 08:10 AM
lbzrango's Avatar
lbzrango
Alright, I'll check that stuff tonight. Thanks.
Old Mar 13, 2012 | 04:54 PM
lbzrango's Avatar
lbzrango
Seems to be the front driver axle. how bad is that to change?
Old Mar 13, 2012 | 09:33 PM
jmess's Avatar
jmess
My first time took about 3.5 hours. Second was a little over 2 hours. Isn't that hard to do.
Old Mar 13, 2012 | 09:36 PM
mikeismadness
The hardest part of doing my ram(almost same setup) was getting the hub bolts out, but a little heat gets em out great
Old Mar 13, 2012 | 11:22 PM
lbzrango's Avatar
lbzrango
Alright thanks guys!
Old Mar 24, 2012 | 11:04 AM
lbzrango's Avatar
lbzrango
Btw it was the axle, mine was destroyed!
took roughly 1.5-2 hours.
