99 Durango back right lock up
Old Mar 22, 2012 | 06:00 PM
scully60's Avatar
scully60
Cool 99 Durango back right lock up
My back left tire locks up/skids if I hit the brakes a little hard. No other problem, no squeals,grinds,thumps or pulling.
Old Mar 22, 2012 | 07:24 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
read the rules and tell me what you did wrong then i will fix it
rules--->https://dodgeforum.com/forum/dodge-d...s-section.html
Old Mar 23, 2012 | 09:15 AM
scully60's Avatar
scully60
Default break lock up
99 Durango SLT , 5.2, 2 wd, automatic
Old Mar 23, 2012 | 09:18 AM
scully60's Avatar
scully60
ok read the rules and posted where I was supposed to with required infomation.
Old Mar 23, 2012 | 07:53 PM
dolittle's Avatar
dolittle
Have you taken the brake drum off? It could be a bad wheel cylinder (leaking) or broken parts. You will need to back off the brakes to take the drum off. Let us know if you need the how to for this.
Old Mar 23, 2012 | 10:01 PM
mikeismadness's Avatar
mikeismadness
Take the drum off and look inside, you might need shoes and to adjust and just clean the brake dust up. It's a pretty common thing around the forum with rear brakes grabbing. Mine do it from time to time
Old Mar 23, 2012 | 10:15 PM
that_guy's Avatar
that_guy
I had the same thing happen with my left rear brake 2 weeks ago and It was because of a leaking wheel cylinder that got fluid on the linings. If that is your problem make sure you replace both wheel cylinders and most likely your linings. It'd also be a good time to replace the springs since you'll have them all off too. I spent $20 on the two wheel cylinders, $20 on the linings, and another $10 on the springs. (my auto adjuster was also shot too so you may want to check yours too $10 to replace them). Also make sure you take lots of pictures before you start ripping things apart and only do one side at a time so that you can refer to the other side for where things go. And if you do replace your linings do not buy them from auto zone.
EDIT:
Make sure you get brake fluid and a few cans of brake clean too
btw shrp, I think you scared an echo out of him. lol
Old Mar 23, 2012 | 10:16 PM
that_guy's Avatar
that_guy
I just posted in your other thread for this issue. Is there an echo in here? lol
Old Mar 23, 2012 | 11:13 PM
mikeismadness
Lol yes I believe so
Old Mar 24, 2012 | 09:29 AM
scully60's Avatar
scully60
no echo.. I was told I posted in the wrong generation.
Thanks for the help
