5.2 pinging/knocking getting worse!
Old 04-07-2012, 11:08 PM
Mechaniczman's Avatar
Mechaniczman
Mechaniczman is offline
well im guna make a trip to the auto parts store, and try all those things, clean up the sludge and ill let yall know if it still pingin.
Anything else in mind i could check out while im under the hood?
Old 04-07-2012, 11:25 PM
samnbensdad's Avatar
samnbensdad
samnbensdad is offline
Please post pics of the supposed "sludge."
Old 04-08-2012, 03:10 PM
Mechaniczman
Will do, hopefully I will have time to take it apart this week. I plan on getting a throttle body gasket and cleaning that too.
Old 04-08-2012, 03:13 PM
mikeismadness's Avatar
mikeismadness
mikeismadness is offline
How's your plenum gasket?
Old 04-08-2012, 10:11 PM
Mechaniczman
I took the air hat off when I did the plugs and opened the throttle and shined a flashlight down in there, I did not see oil seeping in but it was deffinently dirty in there.
Old 04-09-2012, 05:21 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Well a blown plenum gasket would leave oil gathered up in the bottom. Normal engines have normal oil vapor on the inside of the intake, but not large quantity of oil pooled down at the bottom. Besides, 2 quarts in 5K with a motor that has 248K miles on it isn't bad.
The ping is either octane, spark, or plain old worn out parts.
Old 04-09-2012, 11:38 PM
mikeismadness
The different parts of the head couldn't be getting weak. I'm pushing 211,000 and have no ping yet which is awesome! Hopefully u can get your to go awy, best of luck!
Old 04-10-2012, 05:57 PM
samnbensdad
If it really does have sludge, you could have a myriad of problems. Sludge means neglect.
(how long will it take for shrpshtr to scream about the word sludge being used so many times )
Old 04-10-2012, 10:16 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
samnbendsdad is right, sludge is VERY rare in these trucks and is always caused by neglect, even infrequent oil changes will be more than adequet to keep sludge at bay, if you think you have a sludge problem pull the valve covers and post pics or else im not going to believe it. (sludge is one of the most misdiagnosed problem on these trucks)
Old 04-10-2012, 11:33 PM
mikeismadness
He said somewhere in the thread he got a good amount of crud out of the oil fill area so I'm interested to see it myself
Quick Reply: 5.2 pinging/knocking getting worse!
