No Park ??
Old 04-13-2012 | 09:12 PM
Russ50's Avatar
Russ50
Default No Park ??
Hey,, Got a 98 Durango 4X4, The shifter in the floor for the 4X4 is in nutral an when I put my shifter thats on the colum in park my D still moves,,, But when I put the shifter in the floor for the 4X4 in gear then it will go into park good,, I have never owned a 4X4 so Can anybody tell me if this is normal,, Or is the shifter in the floor for the 4X4 is supposed to be put where the 2 is at for 2 wheel drive?
Old 04-13-2012 | 10:08 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if the shifter in the floor is in nuetral the truck will roll even with the transmission in park, this is designed so that you can tow the vehicle w/o leaving the key in the ignition.
in order to lock the driveline when you put it in park you need to have the floor shifter in either 2wd, 4x4 or 4x4lo
Old 04-13-2012 | 10:42 PM
Russ50's Avatar
Russ50
Wow,,,lol, Thanks shapshtr325,,, I am so glad to hear that,,,lol,, I thought for sure that my trans was bad or something,, Wow,,,
Old 04-13-2012 | 10:52 PM
Russ50's Avatar
Russ50
So I will know now to make sure I have the floor shifter in 2 wheel or 4 wheel for park to work,, An do I have to stop to shift from 2 wheel to 4X4 or can it be shift as ya moveing?? Like I said this is my very 1st 4X4 an sure don't want to mess it up,,lol
Old 04-14-2012 | 12:41 AM
that_guy's Avatar
that_guy
you can shift between 2hi and 4hi while moving under 50mph (I may off on that) as long as you're not feeding any gas. You have to stop to go into 4lo since you would be going through neutral. Make sure you don't use 4wd on pavement or you'll mess up the transfer case
Old 04-14-2012 | 08:07 AM
shrpshtr325
THE ULTI-MOD
that_guy, you are close
you can shift 2wd to 4hi or 4hi to 2wd while moving at speeds under 40, you shouldnt use 4wd over 40mph because it will increase drivetrain wear.
for normal driving leave the truck in 2wd and you will be fine, when it snows or you go off road and traction is reduced you can use 4wdhi for that, 4wd low is for low speed high torque situation (pulling a boat up a wet ramp)
in order to get into 4wd low you need to stop and put the transmission into nuetral.
Old 04-14-2012 | 09:08 AM
Russ50's Avatar
Russ50
Now I am understanding how to handle a 4X4 lol,, Thanks guys,, An I won't really be needing the 4X4 that I know of but mite someday at the boat ramp,, But never know,, But at lease I know what to do when time come,,,, Thanks again,,
Old 04-14-2012 | 09:40 AM
that_guy's Avatar
that_guy
I figured I was off by a bit. thanks for clearing that up shrp
Old 04-14-2012 | 08:43 PM
alwaysclean19's Avatar
alwaysclean19
http://www.ebay.com/itm/2000-Dodge-D...r#ht_531wt_905
You should get one, if you don't already have it!
Old 04-14-2012 | 11:02 PM
Russ50's Avatar
Russ50
Hey Thanks alwaysclean19,,, I will see about getting me one so I will have it,,
Quick Reply: No Park ??
