durango
Old Apr 16, 2012 | 02:50 PM
98dodgedurango's Avatar
98dodgedurango
Default durango
I have a 98 durango with the 5.2 it spits and sputters all the time I have fixed/replaced everything that I can think of is there anyone that can help me
Old Apr 16, 2012 | 11:26 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
You may have a bad misfire problem. I will move your post to the correct section.
Old Apr 17, 2012 | 08:45 AM
DomsDodgeDingo's Avatar
DomsDodgeDingo
Do you have a CEL on? If so find out what the codes are then we can go from there.
Old Apr 17, 2012 | 10:51 AM
98dodgedurango
I keep getting the code P0132 short to upstream o2 sensor,I have replaced both sensors twice now.
Old Apr 17, 2012 | 12:57 PM
DomsDodgeDingo
Im having almost the exact same problem! Ive replaced both sensors with Denso(You didnt use Bosch did you?) and traced all the wiring for any shorts and I still have P0132 and sometimes P0138. Mine acted like it was gonna stall alot. I did a full tune-up and it went away. Still have the code but not really as bad.
