Whats the minimum engine compression?
Old Apr 21, 2012 | 08:30 AM
rollin_99's Avatar
rollin_99
Default Whats the minimum engine compression?
Quick question. Whats the minimum engine compression on a 5.2l 318?
Old Apr 21, 2012 | 01:29 PM
mikeismadness's Avatar
mikeismadness
From my understand any engine should have at least 75 psi in each cylinder
Old Apr 21, 2012 | 01:36 PM
rollin_99's Avatar
rollin_99
I hope you mean 175. What is the normal compression?
Old Apr 21, 2012 | 01:40 PM
master tech's Avatar
master tech
Site Moderator & Tech
I always recommend 125 psi as minimum compression. If you have less than 100 psi, you need to find out why.
Old Apr 21, 2012 | 01:44 PM
rollin_99's Avatar
rollin_99
The D is toast. Looking at a used motor with 180psi for 250.
Old Apr 21, 2012 | 02:01 PM
rollin_99's Avatar
rollin_99
Just for sh*t and giggles. What would i need for a 5.9L swap?
Old Apr 21, 2012 | 02:10 PM
rollin_99's Avatar
rollin_99
I'm going to pull it out this upcoming weekend and replace it the weekend after that.
Just want more time to find a good engine, til I can get a create engine next summer.
Old Apr 21, 2012 | 03:08 PM
Mean Green's Avatar
Mean Green
Rollin 180 psi is great compression. I'm not sure on the compression ratio is on the 5.2 but if you have the compression ratio you can multiply that times atmospheric pressure to get an idea where it should be. With 180 psi you are looking at a little over a 12:1 compression ratio at sea level atm pressure
Old Apr 21, 2012 | 05:03 PM
adukart's Avatar
adukart
I'm running about 152-158psi. I don't think you can get much better.
Old Apr 21, 2012 | 06:01 PM
mikeismadness
I had a vehicle at 92 psi and it ran good. Although I had it for 3 mints and sold it because I wanted something else, so idk how long the motor lasted
