Need help with hood project
So I have a spare hood that is the same color as mine. It is just chilling in my storage shed. I was driving the other day and someone had a hood scoop and you could see that they cut a hole in the hood and had a carb filter sticking just above the hood. The scoop covered it but I thought, hey thats not half bad...
So besides the heat extracters that I was already going to put in, anyone think they can help with this?
I am just to cheap to buy a ram hood btw...
So I thought if I was to get one of the oval type carb filters that was say 3" tall, 4"wide, and 7" long I could cut the hood out and place the new filter on the TB and have it stick out of the hood some. Then I would just fab up a hood scoop myself and weld it on. It would be covered, and would pull waaay more cold air in. Plus I could keeep my hood now if I ever wanted to switch back for some reason.
Any thoughts?
Any thoughts?
Any idea on how to find one that will fit the tb? I know I will need to find a longer bolt to attatch it on the tb. I was just going to go K&N personally.
I am torn between bondoing the edges or welding the scoop on to a a plate like edge and using bolts with sealer under it. Just depends on what look I want to go with...
Yea the shaker hood is pretty close. But a new hood would be way more expensive compared to what I am doing with my spare hood. Plus I can custom make it to what I want it to look like.
I am gonna weld it now that I have gone over it. I thought mabey the tough bolted look would be nice but...it would be twice as hard to drill all the holes and then bolt it down, then make it water tight...when I can do it all in one step and weld it.
I should be getting to this shortly. But I am still having trouble finding a filter to fit. Would a basic carb filter mount fine or do the bases come in different sizes? Sorry I have never delt with carbs before...
Trending Topics
I do remember the sectre ones. They are a circle. I don't know if I want to go that big or if I should get one that is more of an oval.
I will have to take pics of the lines I have tapped out and see what you guy's think. My biggest challenge is going to be the actual cutting of the hood.
