Over heating
Old May 2, 2012 | 11:17 AM
Bo1991's Avatar
Bo1991
Default Over heating
This morning after driving for an hour and a half on the interstate I turned off my Durango for about 5 minutes. When I started it again it started to over heat but cooled off after driving it. Then it happened again when I was leaving the gas station but this time it got hot enough for the gage light to come on but then cooled off right away. I haven't noticed any kind of leak so I'm not sure what's going on. Can anyone help?
Old May 2, 2012 | 01:20 PM
adukart's Avatar
adukart
Which year/engine do you have? They had a slightly different set up from the 98-99 than the 00-03.
Old May 2, 2012 | 01:32 PM
Bo1991's Avatar
Bo1991
It's a 2000 5.2 v8 2Wd
Old May 2, 2012 | 02:31 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
two things i would check,
1) the clutch fan
2) the fluid level in the radiator overflow when the engine is cold, if its dry add some in, iirc the 5.2 and 5.9 will work the air out on their own through a run cycle.
Old May 2, 2012 | 02:59 PM
Bo1991's Avatar
Bo1991
I drove it to work this morning. Do you think it's safe to drive home?
Old May 2, 2012 | 03:21 PM
adukart's Avatar
adukart
You should be good as long as you keep moving.
Old May 2, 2012 | 10:50 PM
Bo1991's Avatar
Bo1991
Thanks for the advice!The thermostat doesn't seem to be working so I'm going to replace that first
