Turn Signal problem
Old May 2, 2012 | 10:38 PM
Russ50's Avatar
Russ50
Default Turn Signal problem
After getting my D running good,, My turn siganls was working, Drivers side was flashing faster then the passnger side,, Last night when I was driven my D in then use my siganl an it didn't light up inside on the dash,, I did check all the bulbs this morning an they are all good,, I checked the siganl fuse on the side of the drivers side dash an fuse is good an I did replace it with another 15 amp fuse an still nothing,, My brake lights works an my flashers works,, When I go to turn one of the siganls on then they don't light up on the dash or outside on eigther side, Its just like they are not even hooked up, Only fuse I know about is the one on the side of the dash on the drivers side,, Would anybody know what else I can check to get my siganls working,,,, An this is for my 98 Durango 4X4 with the 5.2 motor,,,,
Old May 2, 2012 | 10:43 PM
RiverH's Avatar
RiverH
Well I'm no expert but if your flashers are working and the turning signals aren't , it's not the bulbs or the turning signals fault, it sounds like it could be something with the turning signal lever ( the one that also controls windshield wipers ), do the wiper controls still work?
Old May 3, 2012 | 09:08 AM
Russ50's Avatar
Russ50
Yea, Thats what has me puzzled,,lol,, The wipes works an the spitter do to,, Just the turn signals just don't work at all inside or outside,,
Old May 3, 2012 | 03:44 PM
mikeismadness's Avatar
mikeismadness
There is fuses in the PDC under the hood I believe. Check there also
Old May 3, 2012 | 07:36 PM
Russ50's Avatar
Russ50
Yea mikeismadness I seen them fusebox under the hood but nothing for turn sigenals
Old May 3, 2012 | 10:08 PM
mikeismadness
Ok. Sounds to me like your switch then
Old May 5, 2012 | 01:29 PM
Mean Green's Avatar
Mean Green
The flasher on the durango is a multifunction flasher and will allow you to have flashers even if the turn signal is inop. I would look into replacing the flasher. From the research I did YEARS ago there is no way to test these accurately, just replace it. Do not go to the dealer unless you want to spend $45 on a flasher...
TRIDON Part # EP27
Rockauto.com $11.00
Old May 5, 2012 | 08:52 PM
Russ50's Avatar
Russ50
Oh ok,, Mean Green where would this flasher be at under the dash ???? an was that the part number with the price from Rockauto.com
Old May 5, 2012 | 09:05 PM
Russ50's Avatar
Russ50
Also,, I had just now looked under my dash,, An on the side of the fuse box that is on the outside of the dash on the side,, I see another lil fuse box under there an looks like a couple fuses are missing Can anyone tell me how many fueses are pos to be in there an what they are for,,
srch4me's Avatar
srch4me
Have you checked your blinker fluid? Lol but in all seriousness check the junkyard? See how much they want vs. rock auto
