Front Sway Bar Bushings
Old May 8, 2012 | 06:59 PM
justin101's Avatar
justin101
Default Front Sway Bar Bushings
This weekend I'm going to change all 4 of the bushings on the front swaybar. What I need to know is how big of a job am I looking at and what kinda grease should I used when i put the new ones on. Also do I need to jack up the truck to do it or no? I got the MOOG brand by the way.
Old May 8, 2012 | 07:54 PM
RollerRed's Avatar
RollerRed
Astoglide for sure! HAHA!
I just finished greasing mine up. I pulled the whole sway bar out and it was easier to just bring the front up on stands(not easy btw, had to get a new set of stands cause mine were to short). Just a couple of bolts, and you will want to either heat the bolts or use PB blaster to loosen it all up.
Why are you changing your bushings btw?
Old May 8, 2012 | 08:34 PM
justin101's Avatar
justin101
The right side a-arm bushing squeaks every time I hit a bump cause its so dry. So I figured if I did one I may as well do them all since it only cost $22 for all four bushings by moog.
Old May 9, 2012 | 01:04 AM
RollerRed's Avatar
RollerRed
True...Mine was doing the same thing and I am just a cheap SOB...so I just greased her up.
Old May 9, 2012 | 10:13 PM
otgarzā's Avatar
otgarzā
https://dodgeforum.com/forum/1st-gen...-bushings.html
This may help. This was when i did it. Yours may be a different setup since its 4x4.
