98y 5.2 v8 magnum valve adjustment
I have bad compresion ratio in two cylinders 6bar and 3bar
So yesterday I try by my sef to correct adjustment with some steel plates under the rocker. I started engine for minute and again tetsted compression ratio and it was up from 3 bar to 8,5 bar
Maybe I have problem with hydraulic lash adjusters? Seems that they are to wide opened
Sorry we are used to compression in PSI can you convert it for us? Get those steel plates out of there and do a wet compression test. To do a wet compression test put some oil down the spark plug hole and then do the compression test. Which cylinders are you low on? Give us as much info as possible no matter how trivial.
3 bar = about 45 psi
8.5bar = about 125 psi
either way those numbers seem low to me, also plates under the rockers is just asking for trouble, the hydraulic adjusters may need to be replaced in order to achieve correct adjustment
