limited slip install / swap?
Old Jun 7, 2012 | 03:41 AM
00 Durango's Avatar
00 Durango
Default limited slip install / swap?
I have a suregrip limited slip from the rear end from my 74 RamCharger that is in excellent shape.
would this fit into the rear axle of my 2000 durango??? tired of a open diff, and getting stuck in the most miniscule puddles/ snow banks etc... the gears and such are all fine, just want a lS, with out the $$$ the LS suregrip unbolts from the ring gear, so i could put it in the Durango, if it fits the case etc...
any thoughts? issues?
has anyone installed a LS in their D?
outcome?
Old Jun 7, 2012 | 08:51 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yes people have installed limited slips/lockers in their D and it works out ok, as for will the one from you 74RC fit, im not sure what you mean by RC, if you mean regular cab (as in a ram p/u) its possible if they both have the same axle then yes.
Old Jun 7, 2012 | 09:20 AM
00 Durango's Avatar
00 Durango
Default L/S in durango?
the suregrip is from my 74' ramcharger 4x4, with the chrysler 1/2 ton 9 1/4? or 8 3/4 ?? rear axle. not sure on spline count. but sure its a 3.73 ratio.
what axle is under the back of our d's???? do they differ by generation? 1,2,3???
Old Jun 7, 2012 | 11:02 AM
that_guy's Avatar
that_guy
I've been researching LSDs lately and I've noticed that when you look them up there are ones that say 84 (might be 85) and up and 84 and older. I think the difference has to do with the abs pickup. I'm not sure if you'd be able to get your abs part to work with the older unit.
Old Jun 7, 2012 | 01:59 PM
srch4me's Avatar
srch4me
I think it won't but not positive. Why not just get a Detroit locker. Yeah its not free but free might not work. Or find a junkyard axle with the factory LSD
Old Jun 7, 2012 | 04:17 PM
shrpshtr325
THE ULTI-MOD
the 3.73 gear ratio will be a problem since you will then need to find a set of 3.73 gears to put into the front end in order to match it up to the rear, if i were you i would simply buy something new for the rear.
Old Jun 7, 2012 | 05:05 PM
that_guy's Avatar
that_guy
It's possible to switch the gears out for his own
Old Jun 7, 2012 | 10:04 PM
shrpshtr325
THE ULTI-MOD
only if the existing gears are in good shape, i read this as his gears are shot and he wants to replace them, if thats not the case then yes it is very likely possible
Old Jun 7, 2012 | 11:21 PM
adukart's Avatar
adukart
I would just find another D in a junkyard or ram with the same Diff and pull the lsd out of it, but thats just me.
Old Jun 8, 2012 | 03:29 AM
Compactc9's Avatar
Compactc9
Or a Dakota, I believe they use the same axels.
