slow down rev at idle.
Old Jun 16, 2012 | 06:32 AM
krupaeric's Avatar
krupaeric
i just bought the truck in the middle of march. so i have no clue when or if it had ever been serviced. which i do not beleive it ever has. it still had the stock metal encased filter on it. but a few weeks ago i did the filter and fluid change. i did not do a band adjustment simply because i had never done one on a vehicle with that tranny so have no idea how to do it. but im guessing it intails me dropping the pan again? if so can i reuse the fluid i just put into it. also would the tv cable and bands not being properly adjusted cause it to slip after it has been running for a while and gotten hot? cuz im having that problem to. after i stop and try to pull away it will either slip and then engage hard, or it will progressively slip into grear slowly. causing me to rev the truck just for it to roll forward. but i also want to add that it will not slip in reverse.
Old Jun 16, 2012 | 06:58 AM
rcs426's Avatar
rcs426
here's a idea find your self a repair shop you can trust they have the training and equipment to properly diagnose proplems you speak of. They spend a lot of time and mony on the proper equipment to fix cars today. AUTOZONE sells parts if you have not adjusted the trans bands before it's diffacult and can caus complete failure if not done correctly!
Old Jun 16, 2012 | 02:19 PM
srch4me's Avatar
srch4me
Don't you think if he wanted take it to a shop he would have? The point of this forum is to help figure out problems not just tell someone to go to a shop.
Pm mastertech, he is the resident tranny guru
Old Jun 16, 2012 | 10:00 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
also band adjustments are not hard if you have the right tools (torque wrench anyone??)
Old Jun 16, 2012 | 11:22 PM
krupaeric's Avatar
krupaeric
can you do the band adjustments without taking off the tranny pan? if so where do i find the bolt to do it. i did it on my buddies dodge van last year and it was easy to locate the bolt and we got the torque specs and how to back it off. but i looked under my d and i didnt see and bolts in the same area as his. so i figured it was a harder job than it was and just didnt do it. but if you or anyone out there has a picture of the bolt and location on the tranny and the specs on it, i would be more than happy to do it myself. but if i got to dropp the pan to it, it may be a while befor i am able to get to it. if you know what i mean. lol.
also i want to add, how everyone here on this forum is so awesome and all they want to do is help ppl, or try to trouble shot there problems. i dont know what i would do if it werent for you guys. i know i would have a alot less money in the bank. lol.
so thanks. and god bless!
Old Jun 17, 2012 | 01:41 AM
srch4me's Avatar
srch4me
Best bet for info is to pm master tech
:-) this place is more than just a help forum its a community :-)
Old Jun 17, 2012 | 07:21 AM
shrpshtr325
THE ULTI-MOD
you can adjust the forward band w/o dropping the pan, but the rear band is located INSIDE the pan, iw ould adjust them at the same time
Old Jun 17, 2012 | 11:22 PM
krupaeric's Avatar
krupaeric
ok so i ended up getting this weekend off so now i got time to do the work needed. so how do i do the band adjustments? front and back. ill drop the pan to do it. i just need to know how to do the adjustments? i got all the tools. sockets torx and digital torque wrench.
